DaimlerChrysler
148534 DRAFT
PREPARATION DATE: 06/18/2003
OSHA HAZARDOUS: YES HAZWOPER HAZARDOUS: YES
HAZARD COMMUNICATION SHEET PAGE I
SUPPLIER: 37637 MFGR: 03500
PART/COMMTY CD: 05016796AA STANDARD: N/AV
CONS PROD OR HAZ SUB: YES
SECTION I - PRODUCT INFORMATION
MFG: PART SALES & SERVICE DAIMLERCHRYSLER
26311 LAWRENCE AVE CENTERLINE Ml 48015
DISTRIBUTED BY: PART SALES & SERVICE DAIMLERCHRYSLER
BRAND NAME: MOPAR TRANSFER CASE LUBRICANT
MFG ID : 805-0284
DESCRIPTION: FLUID-M0B1L 424 HYDRAULIC # *
EMERGENCY PHONE: 248-512-8002
AFTER HOURS: 248-576-8888
DAIMCHRY IND HYGIEN: 248-512-8260
SECTION II - INGREDIENTS
HAZARDOUS INGREDIENTS: PERCENT
COMMON NAME / CAS-NO AND CHEMICAL NAME: BY WEIGHT OSHA ACGIH CHRYS UNITS NOTATIONS
***EXISTING INGREDIENTS’***
KEROSINE 0 .1-1.0 W N/AP 33 100 PPM
008008-20-6 KEROSINE. PETROLEUM A3
PARAFFINIC PROCESS OIL 30-60' W . 5 5 5 MG/M3
O64742-65-OA DISTILLATES (PETROLEUM), SOLVENT-DEWAXE L N/AP 10 10
PARAFFINIC PROCESS OIL 30-60 W 5 5 5 MG/M3
O64742-54-7A DISTILLATES (PETROLEUM), HYDROTREATED H L N/AP 10 10
PHOSPHOROD 1 TH 101C ACID, 0,0-D1-C1 -14-ALKYL ESTERS. 1 -5 W N/AP N/AP N/AP N/AP
068649 -42-3 PHOSPHOROD 1 TH 101C ACID, 0,0-D 1 - С 1 -14 - AL T
FOR EXPLANATION OF 'NOTATIONS1, SEE THE HAZARD COMMUNICATION SHEET EXPLANATIONS PAGE. W = TWA VALUES; L = STEL VALUES; C = CEILING VALUES.
GENERIC DESCRIPTION: N/AV
SECTION III - PHYSICAL DATA
BOILING POINT : N/AV SOLUBILITY IN WATER: N/AV
VAPOR PRESSURE: N/AV EVAPORATION RATE : N/AV REF = : N/AV
VAPOR DENSITY : N/AV SPECIFIC GRAVITY :• N/AV PH AT FULL STRENGTH: ’ N/AV PH AT REC. DILUTION: - N/AV
^VOLATILE BY VOL: N/AV- . VOLATILE ORGANIC COMPOUNDS: N/AV N/AV
ODOR THRESHOLD: N/AV PPM FOR % POPULATION FREEZING POINT: N/AV COEFFICIENT OF WATER/OIL DISTRIBUTION: N/AV
APPEARANCE & ODOR: COMMENT MISSING FOR THIS PART. TO BE ADDED IN FUTURE.
. SECTION IV - FIRE AND EXPLOSION DATA-
FLASH POINT: N/AV . N/AV IGNITION TEMP: N/AV •• У /LEL: N/AV UEL: N/AV
SPECIAL FIRE & EXPLOSION HAZARDS: COMMENT MISSING FOR THIS PART, WILL BE ADDED IN FUTURE.
EXTINGUISHING MEDIA: COMMENT MISSING FOR THIS PART, WILL BE ADDED IN FUTURE.
SPECIAL FIREFIGHTING PROCEDURES: COMMENT MISSING FOR THIS PART. WILL BE ADDED IN FUTURE.
SENSITIVE TO MECHANICAL IMPACT?: N/AV SENSITIVE TO STAT IC D ISCHARGE?: N/AV
HAZARDOUS COMBUSTION PRODS: N/AV.
FLAME PROJECTION: N/AP V ••
SECTION V- HEALTH HAZARD DATA
EFFECTS OF OVEREXPOSURE-ACUTE & CHRONIC: << - --INHALATION - - ■ >> MIST-MAY PRODUCE THE FOLLOWING: COUGH OR MAY BE IRRITATING TO EYES, NOSE. AND THROAT. IF HEATED TO HIGH TEMPERATURE VAPOR MAY PRODUCE THE FOLLOWING: BREATHING DIFFICULTIES. <<- -SKIN CONTACT--->> LIQUID AND/OR MIST MAY PRODUCE THE FOLLOWING: MINOR IRRITATION. REPEATED CONTACT-OR PROLONGED SKIN EXPOSURE MAY RESULT IN THE FOLLOWING: OIL ACNE, FOLLICULITIS OR DERMATITIS. MAY PRODUCE THE FOLLOWING: DEFATTING AND DRYING OF SKIN. INJECTION OF OIL INTO THE SKIN MAY CAUSE PERMANENT LOCAL SKIN DAMAGE. <<---EYE CONTACT---” LIQUID AND/OR MIST MAY PRODUCE THE FOLLOWING: IRRITATION AND TEARING. IF HEATED TO HIGH TEMPERATURE VAPOR MAY PRODUCE THE FOLLOWING: MINOR IRRITATION. << - - -1NGEST ION - - - >> MAY BE HARMFUL IF SWALLOWED. MAY CAUSE UPSET STOMACH, NAUSEA, VOMITING AND DIARRHEA.
EMERGENCY FIRST AID PROCEDURES: <<---INHALATION--->> REMOVE TO FRESH AIR AT ONCE. IF PULMONARY SYMPTOMS DEVELOP. CONSULT A PHYSICIAN. <<---SKIN CONTACT---” REMOVE CONTAMINATED CLOTHING. WASH WITH SOAP AND WATER. IF CONDITION PERSISTS. CONSULT A PHYS 1C IAN. APPLY SKIN CREAM IF DEFATTING OF SKIN OCCURS. <<---EYE CONTACT---” RINSE EYES IMMEDIATELY W1TH LARGE AMOUNTS OF WATER, OCCASIONALLY LIFTING BOTH UPPER AND LOWER LIDS. CONTINUE FOR 15 MINUTES. CONTACT A PHYSICIAN. ««---INGESTION---»» DO NOT INDUCE VOMITING-PETROLEUM BASE CHEMICAL. CONTACT A PHYSICIAN. DRINK LARGE QUANTITIES OF WATER. RINSE MOUTH WITH WATER. NEVER GIVE ANYTHING BY MOUTH TO AN UNCONSCIOUS PERSON. IF VOMITING OCCURS, KEEP HEAD BELOW HIPS TO PREVENT LIQUID FROM SEEPING INTO THE WINDPIPE AND LUNGS.
