Масла Chevron
Масла Chevron
Официальный сайт: http://www.chevronlubricants.com/
Артикулы коды для заказа в инетмагазинах
Вариант № 1
223501482 - Chevron Havoline Motor Oil 0W-20 0,946L
076568796280 - Chevron Havoline Motor Oil 5W-20 0,946L
223393721 - Chevron Havoline Motor Oil 5W-20", 0.946L
223502482 - Chevron Havoline ProDS Full Synthetic 5W-20, 0.946L
223503482 - Havoline ProDS Full Synthetic 5W-30, 0.946L
223394485 - Chevron Havoline Motor Oil 5W-30, 4.73L
223394533 - Chevron Havoline Motor Oil 5W-30, 4.73L
076568796297 - Chevron Havoline Motor Oil 5W-30 0,946L
223726482 -  Chevron Havoline ProDS Full Synthetic 5W-40, 0.946L
223504482 - Chevron Havoline ProDS Euro Full Synthetic 5W-40, 0.946L
223395533 - Chevron Havoline Motor Oil 10W-30, 4.73L
223395481 - Chevron Havoline Motor Oil 10W-30, 0.946L
223396485 - Chevron Havoline Motor Oil 10W-40, 4.73L
223396481 - Chevron Havoline Motor Oil 10W-40, 0.946L
220135721 Chevron Supreme Motor Oil SAE 5W-20 946mL
220013533 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013553 Chevron Supreme Motor Oil SAE 5W-30 4,83L
220013429 Chevron Supreme Motor Oil SAE 5W-30 3,78L
220013719 Chevron Supreme Motor Oil SAE 5W-30 946mL
220155719 Chevron Supreme Motor Oil SAE 10W-30 946mL
220155533 Chevron Supreme Motor Oil SAE 10W-30 4,83L
220059533 Chevron Supreme Motor Oil SAE 10W-40 4,83L
220059429 Chevron Supreme Motor Oil SAE 10W-40 3,78L
220059719 Chevron Supreme Motor Oil SAE 10W-40 946mL
220060719 Chevron Supreme Motor Oil SAE 20W-50 946mL
220060533 Chevron Supreme Motor Oil SAE 20W-50 3,78L
257001388 - Chevron Delo 400 Syn XSP 5W-30 3,785 л
257001448 - Chevron Delo 400 Syn XSP 5W-30 18,9 л
257001981 - Chevron Delo 400 Syn XSP 5W-30 208 л
235195389 CHEVRON DELO 400 Synthetic SAE 0W-30 3,78L
271210339 CHEVRON DELO 400 LE Synthetic SAE 5W-30 3,78L
271210448 CHEVRON DELO 400 LE Synthetic SAE 5W-30 19L
271207448 CHEVRON DELO 400 LE Synthetic SAE 5W-40 19L
271207339 CHEVRON DELO 400 LE Synthetic SAE 5W-40 3,78L
222210339 CHEVRON DELO 400 LE 10W-30 3,78L
222210448 CHEVRON DELO 400 LE 10W-30 19L
222220721 CHEVRON DELO 400 LE 15W-40 946 mL
222220463 CHEVRON DELO 400 LE 15W-40 3,78L
222220478 CHEVRON DELO 400 LE 15W-40 9,946L
222220448 CHEVRON DELO 400 LE 15W-40 19L
224615463 CHEVRON DELO 400 SD SAE 15W-30 3,78L
224615448 CHEVRON DELO 400 SD SAE 15W-30 19L
235101448 CHEVRON DELO 400 Multigrade SAE 15W-40 19L
235101339 CHEVRON DELO 400 Multigrade SAE 15W-40 3,78L
235101721 CHEVRON DELO 400 Multigrade SAE 15W-40 946mL
271220722 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 946mL
271220448 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 19L
271220339 CHEVRON DELO 400 XLE Synthetic Blend SAE 10W-30 3,78L
Вариант №2
235101721           CHEVRON  DELO ® 400  15W-40 CI-4 plus       0.946л.
01020013           CHEVRON  DELO ® 400  15W-40 CI-4 plus       3.785л.
01020012           CHEVRON  DELO ® 400  15W-40 CI-4 plus      18.9л.
235101981           CHEVRON  DELO ® 400  15W-40 CI-4 plus      208л.
01020012           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      18.9л.
01020011           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus      208л.
01020013           CHEVRON  DELO ® 400 SD 15W-30 CJ-4 plus   3.785л.
235105339           CHEVRON  Delo®     400 MGX SAE 15W-40         3.785л.
235105428           CHEVRON  Delo®     400 MGX SAE 15W-40       18.9л.
235105981           CHEVRON  Delo®     400 MGX SAE 15W-40       208л.
8888880           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40     20л.
8888881           CHEVRON DELO XLD  MULTIGRADE SEMI SYNTHETIC 10W-40    208л.
271201448           CHEVRON URSA  SUPERPLUS  EC 15W-40    18.9л.
271201981           CHEVRON URSA  SUPERPLUS  EC 15W-40    208л.
222210448           DELO 400 LE 10W-30  18.9л.
222210981           DELO 400 LE 10W-30  208л.
222210339           DELO 400 LE 10W-30  3.785л.
01020048           DELO 400 LE 15W-40  0,946л.
222220448           DELO 400 LE 15W-40  18.9л.
222220981           DELO 400 LE 15W-40  208л.
222220463           DELO 400 LE 15W-40  3.785л.
271210448           DELO 400 LE SYNTHETIC 5W-30  18.9л.
271210981           DELO 400 LE SYNTHETIC 5W-30  208л.
271210339           DELO 400 LE SYNTHETIC 5W-30  3.785л.
271207448           DELO 400 LE SYNTHETIC 5W-40  18.9л.
271207981           DELO 400 LE SYNTHETIC 5W-40  208л.
271207339           DELO 400 LE SYNTHETIC 5W-40  3.785л.
235101721           DELO 400 MULTIGRADE 15W-40  0.946л.
235101448           DELO 400 MULTIGRADE 15W-40  18.9л.
235101981           DELO 400 MULTIGRADE 15W-40  208л.
235101339           DELO 400 MULTIGRADE 15W-40  3.785л.
01020051           DELO 400 SAE 10W  18.9л.
235109981           DELO 400 SAE 10W  208л.
01020051           DELO 400 SAE 40  18.9л.
235195351           DELO 400 SYNTHETIC 0W-30  0.946л.
235195448           DELO 400 SYNTHETIC 0W-30  18.9л.
235195981           DELO 400 SYNTHETIC 0W-30  208л.
235195389           DELO 400 SYNTHETIC 0W-30  3.785л.
01020047           DELO 400 XLE  Synblend 10W-30  18.9л.
01020007           DELO 400 XLE  Synblend 10W-30  208л.
01020048           DELO 400 XLE  Synblend 10W-30  3.785л.
254591542           CHEVRON BLACK PEARL GREASE  EP 2     397г
255659642           CHEVRON MOLY GREASE        EP NLGI 1     397г
01020290           CHEVRON MOLY GREASE        EP NLGI 1    182кг
255660642           CHEVRON MOLY GREASE        EP NLGI 2     397г
01020295           CHEVRON MOLY GREASE        EP NLGI 2    182кг
255660451           CHEVRON MOLY GREASE        EP NLGI 2   15.9кг
274509451           CHEVRON MULTIFAK                EP 00   15.9кг
01020303           CHEVRON MULTIFAK                EP 1     397г
01020302           CHEVRON MULTIFAK                EP 1   15.9кг
274503642           CHEVRON MULTIFAK                EP 2     397г
274503451           CHEVRON MULTIFAK                EP 2   15.9кг
01020218           CHEVRON RPM ARCTIC GREASE        EP NLGI 1    397г
01020218           CHEVRON RYKOTAC  GREASE        EP     397г
254504642           CHEVRON SRI GREASE        NLGI 2     397г
277111642           CHEVRON STARPLEX                EP 2     397г
250186642           CHEVRON ULTI-PLEX GREASE   EP NLGI 1     397г
250185642           CHEVRON ULTI-PLEX GREASE   EP NLGI 2     397г
250188642           CHEVRON ULTI-PLEX GREASE SYNT EP   1.5   397г
01020250           CHEVRON ULTRA-DUTY         EP NLGI 0     397г
238012642           CHEVRON ULTRA-DUTY         EP NLGI 1     397г
238011642           CHEVRON ULTRA-DUTY         EP NLGI 2     397г
235212451           DELO GREASE EP NLGI 00  15.9кг.
01020218           DELO GREASE EP NLGI 1  397г.
235208451           DELO GREASE EP NLGI 2  15.9кг.
235208642           DELO GREASE EP NLGI 2  397г.
01020218           DELO GREASE ESI  397г.
222206642           DELO HEAVY DUTY  EP 2  397г.
222231451           DELO HEAVY DUTY MOLY 3%  EP 2  15,9кг.
01020205           CHEVRON 2 CYCLE OIL             TC-W3     18,9л
01020204           CHEVRON 2 CYCLE OIL             TC-W3  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/20  0.946л
01020151           CHEVRON SUPREME 100% SYNTHETIC   5/30  0.946л
01020158           CHEVRON SUPREME 100% SYNTHETIC   5/40  0.946л
01020152           CHEVRON SUPREME 100% SYNTHETIC  10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL         5/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/30  0.946л
01020123           CHEVRON SUPREME HI MI MOTOR OIL       10/40  0.946л
01020142           CHEVRON SUPREME MOTOR OIL          30  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/20  0.946л
01020103           CHEVRON SUPREME MOTOR OIL        5/30  0.946л
01020102           CHEVRON SUPREME MOTOR OIL        5/30  3.785л
01020113           CHEVRON SUPREME MOTOR OIL       10/30  0.946л
01020111           CHEVRON SUPREME MOTOR OIL       10/30  208л.
01020112           CHEVRON SUPREME MOTOR OIL       10/30  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/30  4,73 л
01020123           CHEVRON SUPREME MOTOR OIL       10/40  0.946л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  3.785л
01020122           CHEVRON SUPREME MOTOR OIL       10/40  4,73 л
01020133           CHEVRON SUPREME MOTOR OIL       20/50  0.946л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  3.785л
01020132           CHEVRON SUPREME MOTOR OIL       20/50  4,73 л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O   5/30  0.946л
01020152           CHEVRON SUPREME SYNTHETIC BLEND M/O 10/30  0.946л
SAIC-GM Full Synthetic 0W-20 Chevron-Tianjin Made in China
SAIC-GM Full Synthetic 5W-30 Chevron-Tianjin Made in China
Chevron Delo 400 Syn XSP 5W-30 API CK-4
Chevron Delo LE 400 5W-40
Chevron Delo LE 400 5W-30
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2
Лабораторные анализы - Отработки - UOAoil-club.ru
Chevron Havoline ProDS 0W-20 API SN Dexos1 Gen2 отработка на Toyota Rav4 после 9460км
Chevron Delo 400LE Synthetic 5W-40 отработка на Dodge Ram 2500 после 8200 км.
Chevron Delo 400 XLE Synblend 10W-30 CJ-4 отработка на Ford Focus ST после 8000 км.
Chevron Delo 400 LE Synthetic 5W-40 отработка на Dodge Ram после 16790 км.
torcon
Ребята этой минералка 2й группы не забывайте
да пофиг, я вот как обычный человек, непонимаю и не должен понимать что такое минералка или синтетика или ещё что. Я просто посмотрел что это 5w-30!!! а это значит что это для зимы нормально, и купил а на самом деле это 15w-50 оказалось например, вот поэтому Шеврон и терпеть немогут.
Zver ну так потрудись хотя бы как обычный человек узнать температуру замерзания масла -36 это на самом деле мало для нашего климата! Тут семи пядей во лбу не нужно быть. И еще SAE не говорит что 5W30 можно использовать при -35 - НИГДЕ НЕГОВОРИТ! Читай стандарт SAE J300 - там только температура холодного пуска и прокачиваемость при отрицательных. Просто мы любим верить в сказки и слухи и обростаем стереотипами - в этом проблема нашего народа.
"5W30 а значит можно"
"SCT Germany - значит в германии сделано"
"Full Synthetic - значит синтетика ПАО"
"Shell - значит в перьми разливают"
"BP в москве"
"Teboil - Лукойл"
итд...
нет ну ты тогда скажи зачем вообще тогда писать цифры 5w-10w-15w???? они ведь и должны показывать температуру застывания масла
Zver они должны показывать "рамки".
К примеру есть 5W40 с температурой застывания -39 и есть 5W40 с температурой застывания -54 (реально есть такие масла на разной базовой основе!).
Ты живешь не в Тюмени а в Норильске где -40 -50 запросто. Наступает мороз под -40. У тебя в канистре 1ое масло превращается в солидол. Ты начинаешь блажить, да что же это за масло такое, ведь это 5W40 - его можно зимой лить! Ответ не все 5W40 одинаковы! Не во всех климатических зонах зимой максимум -30 -35... Бывает и похлеще!
Возьми Chevron Supreme Synthetic 5W30 у которого -52 тебе рядом с ним Mannol Elite 5W40 который якобы на ПАО покажется говномаслом. Ну разные они все, что я могу поделать :spiteful:
а вот давай, дабы не быть голословными, проведём тест, зима ведь ещё впереди! ты мне Суперма этого дашь чуть чуть, а я тебе Элита! И сравним!
Zver и где же я его возьму? :spiteful:
Его нет у нас в продаже к сожалению.
Zver абсолютно поддерживаю тебя, на счет вязкостей масла. Я тоже так считаю, что индекс 5W, должен укладываться в одни темп. рамки, индекс 0W, в другие, 10W, в третьи. Большая часть автолюбителей - безграмотные люди. Я очень много баек наслышался от товарища, который работал в автомагазине. Многие даже не знают, где ручка, чтобы капот дернуть! Другие ездят на одном масле по 40000 км... Я уже не говорю ни про какие SAE J300. Мое мнение, зимнее масло должно быть с индексом 5W и темп у него должна быть от -30 до -35. И не на градус не больше. Иначе получается белиберда. Одно масло 5W40 колом застывает в -30, другое, с тем же индексом, легко плещиться в канистре - не порядок.
Dimasgen ну вот Chevron и замерз между -30 и -35 в "твоих рамках" :)
Посмотри вот этот ролик http://www.autoclub72.ru/forum/index.php?s...ost&p=28803
Одно масло 5W30 в -40 текет сразу, другое 5W30 через пару минут только вытекает из бутылки. Оба 5W30! Все масла разные, несмотря на одну вязкость по SAE - ты не знал? :D
Я по опыту над Chevron Supreme 5W30 понял одно, для нашей тюменской зимы оно не подходит, надо брать повыше классом Chevron Synthetic. А летом нормальный вариант, я лил - тихо, не горит, все ок. Petro-canada Supreme если такая же окажется буду переходить на более синтетичный продукт.
torcon
Кстати, тут в документе у Шеврона действительно указано Pour Point -36, но Pour Point - это не темп замерзания, а температура прокачивания. А это резные вещи. А если исходить из результатов теста, то какая уж тут прокачиваемость...
Dimasgen ты не прав.
Pour Point - Температура застывания! Воспользуйся переводчиком.
Температура прокачиваемости указывается по другому. Там ее нет. Там есть вязкость при холодной прокрутке.
torcon ты не подумай, я не против масла Шеврон. Оно мне очень симпотизирует и Петро-Канада тоже, его собираюсь залить ближе к весне-лету. Просто дело в том, что когда на прилавке стоят две канистры, обе 5W30, то где же правда?
torcon
Pour (ПО) - литься, отливать, сыпать
Point (ПОИНТ) - точка.
Как я понял это точка текучести. Или другими словами тем. прокачивания. Я конечно, с таким авторитетом, по маслам, как ты спорить не буду, просто как перевел, так и понял.
http://translate.google.ru/?hl=ru#
Впринципе забудь, это значение обозначает и дословно - точка застывания(температура застывания), и потеря текучести скажем так - если подумать одно и тоже, теже яйца только в профиль :)
Впринципе забудь это значение обозначает и дословно точка застывания(температура застывания) и потеря текучести скажем так - если подумать одно и тоже, теже яйца только в профиль
Понтненько, будем знать :)
