Jump to content
Моторные масла Kixx!
Завод смазочных материалов!
Sign in to follow this
IliaP.
ДНП имеет такое же значение как и октан.А также про бензин для высокогорья.
Recommended Posts
С официального сайта техники Briggs&Stratton. Для сомневающихся в ДНП!
What is the best small engine or lawn mower gas?
Fuel for your lawn mower or outdoor power equipment must meet these requirements:
  • Clean and fresh - fuel can begin to deteriorate in as little as 30 days
  • A minimum of 87 octane/87 AKI (91 RON); If operating at high altitude, see below
  • Gasoline with up to 10% ethanol (gasohol) or up to 15% MTBE (methyl tertiary butyl ether), is acceptable. Some fuel stations are now selling gasoline with up to 15% ethanol. This E15 product is not recommended or approved for use in small engines.
  • A canned fuel product can also be used. This fuel combines ethanol-free unleaded gasoline with a fuel stabilizer to prolong the life of the fuel.
  • Fuel RVP rating is equally as important as the octane rating. Gasoline refineries raise and lowers fuel RVP ratings seasonally to account for the differences in temperature.
  • Summer Fuel = low RVP rating
  • Winter Fuel = high RVP rating
  • ** This rating varies from state to state also **
Note: LOOK BEFORE YOU PUMP! Do not use unapproved gasoline, such as E15 and E85. Do not mix oil in gasoline or modify the engine to run on alternate fuels. Use of unapproved fuels will damage the engine components, which will not be covered under warranty.
Fuel Recommendation for High Altitude Climates
At altitudes over 5,000 feet (1524 meters), a minimum 85 octane / 85 AKI (89 RON) gasoline is acceptable. To remain emissions compliant, high altitude adjustment is required. Operation without this adjustment will cause decreased performance, increased fuel consumption, and increased emissions.
ДНП также важен как и октановое число. Летнее топливо-низкий ДНП! Зимнее-высокий!
Также рекомендации про использование бензина в условиях высокогорья.
Share this post
Link to post
Share on other sites
Накой эта хрен тут для газонокосилок? :D
Share this post
Link to post
4 минуты назад, Lacoste сказал:
А что, в горах трава не растет? Вот решил ты вдруг поехать в знаменитые подмосковные горы травы накосить, а бензокоса раз - и не завелась. Чтобы такого не произошло, нужно ЗИМОЙ в горах при попытке косить траву заливать бенз с правильным ДНП.
Share this post
Link to post
Только что, СИНТЭКС сказал:
:)):D
Ну да, как же я не подумал то)
Share this post
Link to post
Так может траву не нужно косить, может речь про другую траву :D
50 минут назад, СИНТЭКС сказал:
Там теперь  в Некрасовке не ростет :cray:
Edited by SVali
Share this post
Link to post
Share this post
Link to post
2 часа назад, IliaP. сказал:
В чем полезность приведенных рекомендаций? мне казалось многие форумчане давно в курсе этого.
Если уж про американский бензин говорить, то мне вот другое интересно - почему в американском мануале на авто в качестве рекомендованного указан бензин с ОЧ = 87 AKI (т.е. АИ-92), а в российском для точно такого же двигателя рекомендован АИ-95 и выше.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Create New...
