Масла Areol
Масла Areol
Официальный сайт:  http://www.areollub.com/
Нарвался на просторах интернета на такое вот масло под названием Areol, производится типа в Нидерландах.
каталог http://armtek.by/wp-content/uploads/2017/10/Katalog-masel-AREOL.pdf
продвигается белорусским Armtek
5W30AR015 - Areol Max Protect F 5W-30 1L
5W30AR016 - Areol Max Protect F 5W-30 4L
5W30AR017 - Areol Max Protect F 5W-30 5L
5W30AR044 - Areol Max Protect F 5W-30 20L
5W30AR045 - Areol Max Protect F 5W-30 60L
5W30AR046 - Areol Max Protect F 5W-30 205L
5W40AR011 - Areol Max Protect 5W-40 1L
5W40AR010 - Areol Max Protect 5W-40 4L
5W40AR009 - Areol Max Protect 5W-40 5L
5W40AR038 - Areol Max Protect 5W-40 20L
5W40AR039 - Areol Max Protect 5W-40 60L
5W40AR040 - Areol Max Protect 5W-40 205L
10W40AR002 - Areol Max Protect 10W-40 1L
10W40AR003 - Areol Max Protect 10W-40 4L
10W40AR001 - Areol Max Protect 10W-40 5L
10W40AR032 - Areol Max Protect 10W-40 20L
10W40AR033 - Areol Max Protect 10W-40 60L
10W40AR034 - Areol Max Protect 10W-40 205L
5W40AR060 - Areol Eco Protect 5W-40 1L
5W40AR061 - Areol Eco Protect 5W-40 4L
5W40AR062 - Areol Eco Protect 5W-40 5L
5W40AR063 - Areol Eco Protect 5W-40 20L
5W40AR064 - Areol Eco Protect 5W-40 60L
5W40AR065 - Areol Eco Protect 5W-40 205L
5W30AR018 - Areol Eco Protect 5W-30 1L
5W30AR019 - Areol Eco Protect 5W-30 4L
5W30AR020 - Areol Eco Protect 5W-30 5L
5W30AR047 - Areol Eco Protect 5W-30 20L
5W30AR048 - Areol Eco Protect 5W-30 60L
5W30AR049 - Areol Eco Protect 5W-30 205L
0W20AR068 - Areol Eco Energy DX1 0W-20 5L
0W20AR067 - Areol Eco Energy DX1 0W-20 4L
0W20AR066 - Areol Eco Energy DX1 0W-20 1L
0W30AR057 - Max Protect 0W-30 1L ACEA A3/B4
0W30AR058 - Max Protect 0W-30 4L ACEA A3/B4
0W30AR059 - Max Protect 0W-30 5L ACEA A3/B4
5W30AR074 - Areol ECO Energy DX1 5W-30 5L
5W30AR073 - Areol ECO Energy DX1 5W-30 4L
5W30AR072 - Areol ECO Energy DX1 5W-30 1L
5W30AR006 AREOL ECO Protect Z 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR007 AREOL ECO Protect Z 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR008 AREOL ECO Protect Z 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, MB 229.51/229.52, VW 502.00
5W30AR012 AREOL Max Protect LL 5W-30 (1L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR013 AREOL Max Protect LL 5W-30 (4L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR014 AREOL Max Protect LL 5W-30 (5L) масло моторное! синт.\ ACEA A3/B4, API SN/CF, MB 229.3/226.5
5W30AR018 AREOL ECO Protect 5W-30 (1L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR019 AREOL ECO Protect 5W-30 (4L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
5W30AR020 AREOL ECO Protect 5W-30 (5L) масло моторное! синт.\ ACEA C3, API SN, VW 504.00/507.00, MB 229.51
Грузовая Программа:
10W40AR004 AREOL Trans Truck 10W-40 (20L) масло моторное! полусинт.\ ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR005 AREOL Trans Truck 10W-40 (205L) масло моторное! полусинт.\ACEA A3/B4/E7, API CI-4/SL, MB 228.3/229.1
10W40AR025 AREOL Trans Truck ECO 10W-40 (20L) масло моторное! синт.\ACEA E6/E7, API CI-4, Volvo VDS-3,MAN M3477
10W40AR026 AREOL Trans Truck ECO 10W-40 (205L) масло моторное! синт.\ACEA E6/E7, API CI-4,Volvo VDS-3,MAN M3477
Areol Max Protect 5W-40 API SN
Areol Trans Truck 10W-40 API CI-4
Areol Max Protect 0W-30
Areol Eco Protect C2 5W-30
Areol Eco Energy DX1 0W-20 API SP
Areol Eco Protect 5W-30 2022
Areol Eco Energy DX1 5W-30
Areol EcoProtect 5W-30 канистра март 2018 года
Areol Max Protect LL 5W-30
Areol Eco Energy DX1 0W-20  отработка на Toyota Rav4 после 9300км
torcon В шапке нет артикулов 0W20
12.05.2020 в 04:07, torcon сказал:
Друзья это мои слова, за свои слова могу ответить. К Areol отношусь с симпатией за их дешевый ценник и содержимое, прошу меня не зачислять в антипиарщики и не строить конспирологии. Что вижу то говорю...
Вот анализы масел 0W-30 стандарта ACEA A3/B4
Вы видите там где то масло с вязкостью 9.9?
Вот тех. документация на ваше масло
Вы видите там где то вязкость 9,9?
Если попытаться отнекаться, то да можно ухватиться за последний аргумент - SAE J300 где указано что SAE 30 должна быть от 9,3 до 12,5.
Но у вас не просто SAE 0W-30, у нее есть и другие стандарты например ACEA A3/B4 где HTHS > 3.5. А так же спецификации немецких компаний, где все это тоже перечислено.
Не путайте пожалуйста причинно следственную связь. Если вы объективные люди, Вам нужно валить вину не на того, кто показал вам неточность продукта, а писать на завод и спрашивать с них, почему они такое масло сделали. Я то тут причем? Или нам теперь масла не тестировать?
Я согласен, вязкость при 100 С занижена, но не критично.
А где в результатах теста видно, что показатель HTHS ниже 3,5? Его там вообще нет. А в соответствии с SAE J300  этот показатель у 30 класса вязкости не ниже 2,9. Судя по вашей логике масел XW-30 A3/B4 вообще не бывает.
tutish реально не доходит о чем  Торкон пишет или потролить решил?
*w-30 a5/b5 hths от 2.9 до 3.5
*w-30 a3/b3/b4 hths от 3,5 и выше
Данная партия масла Брак, это масло не может на своем борту иметь АСЕА а3/b3/b4
19 минут назад, tutish сказал:
Мы судим о нём по вязкости отталкиваясь от показателей других масел.
20 минут назад, tutish сказал:
Для выполнения требования А3/В4(HTHS не ниже 3.5) вязкость 30-к должна быть в районе 12сСт. А ваше масло этим требованиям не удовлетворяет.
13 минут назад, ModeratorSigma сказал:
по моему один вариант выходит из другого:sarcastic:
20 часов назад, ModeratorSigma сказал:
Я хочу разобраться и для этого свяжусь с поставщиками и попрошу их предоставить еще одни результаты экспертизы из другой лаборатории. Для установления истины в данном вопросе одного протокола мало. Если нужно, заплачу. Истина дороже.
tutish, если открыть отзывы на этот продукт, в РБ он массовый, столкнётесь с очень большим количеством коментариев "масло как вода" и в этом роде. Тем более, реальных допусков я не наблюдаю у масла.
tutish
5 минут назад, tutish сказал:
этого же масла, этой же партии , но другой лаборатории?
Можете поделить масло по частям одну отправить в одну лабу , другую половину в другую лабу и вообще не называть масло.
Подобное мы уже делали и не раз, если интересно поищу и дам ссылку
11 минут назад, tutish сказал:
а вот тут может крыться заковырка - сталкивались уже с подобным.
Масло с розницы имеет одни хар-ки (кряк), а масло от офпостащиков другие (ПАО)
те офпоставщики присылают на анализ масло из спецзамеса, а далее  в продажу идет уже оптимизированный продукт
34 минуты назад, ModeratorSigma сказал:
на анализ масло из спецзамеса, а в продажу идет оптимизированный продукт
На этом ловили многих производителей и не только моторных масел, а автомобилей, шин и т.д.
Финны из Нокиа признались, что на тесты предоставляются специальные шины, а в продажу "оптимизированные", то есть со значительно сниженными характеристиками.
На форуме есть темы по попавшимся на вранье автопроизводителям - BMW, VW, MB.
Европа давно такая, с этим надо смириться, либо не пользоваться европродукцией.
15.05.2020 в 12:47, tutish сказал:
Как продвигаются дела в поисках истины?:popcorm:
5-40 MAX льем в такси,  на дорогое масло денег нет, но и минералку не хочется лить. В парке шкоды октавии, киа оптима, солярисы, форд мондео, ниссан алмера, рено логан, рено флюенс. Стараемся менять каждые 9-10 тыс. перекаты случаются. Моточасы огромные. Самые первые авто, в которые залили это масло на данный момент прошли 270000(солярис) 290000(логан), самый минимум 40000(оптимы). На солярисе пробило прокладку гбц, мотор вскрывался по этой причине. Нагара, грязи и шлака практически нет, практически т.к немного все же присутствует(общий пробег 350000). октавии пробежали на этом масле от 100000 до 210000 (эти как жрали с завода, так и продолжали). К чему я, к тому, что масло не плохое, в режиме такси откатано и никаких вопросов к моторам не было. Я понимаю, что моторы разные, и масло должно быть разной вязкости и т.д, это хорошо на своих машинах, в таксопарках не льют дорогие масла, не рентабельно. И разные масла не покупают, есть на то причины. Порядка 40-50 машин катаются на этом масле под моим присмотром, пока ни одна не сдалась из-за масла. А лить в свой авто или нет решает каждый сам. в свою личную лью, но интервал замены у меня 7000, что на этом, что на предыдущих маслах. пробег на моей 397000.
вот все взяли вам и поверили, как будто у вас другой ареол, или все лохи неправильно подбирают масло.
всем давно ясно что масло фуфло.
SergAgent да нормальное масло, ну подумаешь завод сделал маленький наебек, с кем "лукойл" не бывает:sarcastic:
Истина дороже.
Пошёл второй месяц в поисках истины... мой друг, как вы там, как успехи в разоблачении ойл клуба?:sarcastic:
