Масла Aral
Официальный сайт: http://www.aral-lubricants.com
Каталог масел: https://www.aral-lubricants.de/en/lubricants/aral-engine-oils/engine-oils-for-passenger-cars
Первый вариант кодов
Aral SuperTronic SAE 0W-40 1l - 20458
Aral SuperTronic SAE 0W-40 4l - 20459
Aral SuperTronic SAE 0W-40 60l - 10451
Aral SuperTronic SAE 0W-40 208l - 20450
Aral SuperTronic G SAE 0W-30  1l - 10382
Aral SuperTronic G SAE 0W-30 4l - 10383
Aral SuperTronic G SAE 0W-30 208l – 10385
Aral SuperTronic Longlife II SAE 0W-30 60l – 10321
Aral SuperTronic E SAE 0W-30 1l – 10508
Aral SuperTronic Longlife III SAE 5W-30 1l  - 20478
Aral SuperTronic Longlife III SAE 5W-30 4l - 20479
Aral SuperTronic Longlife III SAE 5W-30 60l - 10471
Aral SuperTronic Longlife III SAE 5W-30 208l – 20470
Aral HighTronic С SAE 5W-30 1l - 10589
Aral HighTronic С SAE 5W-30 4l – 10584
Aral HighTronic G SAE 5W-30 1l - 21387
Aral HighTronic G SAE 5W-30 4l - 21384
Aral HighTronic G SAE 5W-30 60l - 21381
Aral HighTronic G SAE 5W-30 208l  - 21380
Aral HighTronic J SAE 5W-30 1l - 20198
Aral HighTronic J SAE 5W-30 4l - 20194
Aral HighTronic J SAE 5W-30 60l - 20191
Aral HighTronic J SAE 5W-30 208l – 20190
Aral HighTronic R SAE 5W-30 1l - 16008
Aral HighTronic R SAE 5W-30 4l – 16004
Aral HighTronic F SAE 5W-30 1l - 10332
Aral HighTronic F SAE 5W-30 60l - 3692
Aral HighTronic F SAE 5W-30 208l – 10333
Aral ECOTronic F SAE 5W-20 1l - 25097
Aral ECOTronic F SAE 5W-20 4l – 25094
Aral MegaTronic SAE 10W-60 1l - 24927
Aral MegaTronic SAE 10W-60 4l – 10228
Aral HighTronic SAE 5W-40 1l - 20637
Aral HighTronic SAE 5W-40 4l - 20634
Aral HighTronic SAE 5W-40 5l - 20635
Aral HighTronic SAE 5W-40 20l - 20633
Aral HighTronic SAE 5W-40 60l - 20631
Aral HighTronic SAE 5W-40 208l – 20632
Aral HighTronic М SAE 5W-40 1l - 21407
Aral HighTronic М SAE 5W-40 4l - 21404
Aral HighTronic М SAE 5W-40 60l - 21401
Aral HighTronic М SAE 5W-40 208l – 21400
Aral BlueTronic SAE 10W-40 1l - 20488
Aral BlueTronic SAE 10W-40 4l - 20484
Aral BlueTronic SAE 10W-40 5l – 20485
Aral BlueTronic SAE 10W-40 20l - 10487
Aral BlueTronic SAE 10W-40 60l - 10481
Aral BlueTronic SAE 10W-40 208l -  20480
Aral SuperTurboral SAE 5W-30 4l - 11488
Aral SuperTurboral SAE 5W-30 20l - 11482
Aral SuperTurboral SAE 5W-30 208l – 11489
Aral SuperTurboral LA SAE 5W-30 20l - 20353
Aral SuperTurboral LA SAE 5W-30 60l - 20351
Aral SuperTurboral LA SAE 5W-30 208l – 20350
Aral MegaTurboral SAE 10W-40 5l - 10625
Aral MegaTurboral SAE 10W-40 20l - 13932
Aral MegaTurboral SAE 10W-40 60l - 13931
Aral MegaTurboral SAE 10W-40 208l – 23930
Aral MegaTurboral LA SAE 10W-40 20l - 13962
Aral MegaTurboral LA SAE 10W-40 208l – 13961
MegaTurboral VR SAE 10W-40 20l – 20203
MegaTurboral S SAE 10W-40 208l – 20131
Aral  Turboral SAE 10W-40 1l - 21197
Aral  Turboral SAE 10W-40 5l - 22004
Aral  Turboral SAE 10W-40 20l - 22003
Aral  Turboral SAE 10W-40 60l - 22001
Aral  Turboral SAE 10W-40 208l – 22000
Aral Turboral SAE 15W-40 5l - 22014
Aral Turboral SAE 15W-40 20l - 11281
Aral Turboral SAE 15W-40 208l – 22119
Aral Getriebeöl EP SYNTH. SAE 75W-90 1l – 25467
Aral Getriebeöl EP 85W-90 1l – 15108
Aral  Getriebeöl  EP Plus 80W-90 20l - 15452
Aral  Getriebeöl  EP Plus 80W-90 60l - 15454
Aral  Getriebeöl  EP Plus 80W-90 208l – 25450
Aral Getriebeöl HYP 85W-90 1l - 14257
Aral Getriebeöl HYP 85W-90 20l – 14303
Aral Getriebeöl BS LSX SAE 75W-140 20l – 26342
Aral Getriebeöl ATF 22 1l - 15973
Aral Getriebeöl ATF 22 20l – 15968
Aral Getriebeöl ATF 22 208l – 15970
Aral Getriebeöl ATF 55 1l - 15928
Aral Getriebeöl ATF 55 20l – 15922
Aral Getriebeöl ATF J 1l - 56638
Aral Getriebeöl ATF J 20l -  56633
Aral Getriebeöl ATF E-S 1l – 15878
Aral Antifreeze Extra 1l – 90829
Aral Antifreeze Silikatfrei 1l - 90839
Второй вариант кодов:
4003116106259 Моторное масло ARAL MegaTurboral SAE 10W-40 (5л)
4003116204597 Моторное масло ARAL SuperTronic SAE 0W-40 (4л)
4003116204849 Моторное масло ARAL BlueTronic SAE 10W-40 (4л)
4003116204887 Моторное масло ARAL BlueTronic SAE 10W-40 (1л)
4003116212745 Моторное масло ARAL Plus Turboral SAE 15W-40 (4л)
4003116103326 Моторное масло ARAL HighTronic F SAE 5W-30 (1л)
4003116220047 Моторное масло ARAL Turboral SAE 10W-40 (5л)
4003116220078 Моторное масло ARAL Turboral SAE 10W-40 (1л)
4003116220146 Моторное масло ARAL Turboral SAE 15W-40 (5л)
4008177991288 Моторное масло ARAL Turboral SAE 10W-40 (20л)
4003116105894 Моторное масло ARAL HighTronic C SAE 5W-30 (1л)
4003116114889 Моторное масло ARAL SuperTurboral SAE 5W-30 (4л)
4003116142578 Трансмиссионное масло ARAL Getriebeol Hyp SAE 85W-90 (1л)
4003116151082 Трансмиссионное масло ARAL Getriebeol EP SAE 85W-90 (1л)
4003116158784 Трансмиссионное масло ARAL Getriebeol ATF E-S (1л)
4003116159286 Трансмиссионное масло ARAL Getriebeol ATF 55 (1л)
4003116159736 Трансмиссионное масло ARAL Getriebeol ATF 22 (1л)
4003116160084 Моторное масло ARAL HighTronic R SAE 5W-30 (1л)
4003116201985 Моторное масло ARAL HighTronic J SAE 5W-30 (1л)
4003116213971 Моторное масло ARAL HighTronic M SAE 5W-30 (1л)
4003116566381 Трансмиссионное масло ARAL Getriebeol ATF J (1л)
4003116908297 Антифриз концентрированный бесцветный ARAL Antifreeze Extra (1л)
4003116908396 Антифриз концентрированный красный ARAL Antifreeze Silikatfrei (1л)
2200000013262 Моторное масло ARAL Extra Turboral SAE 10W-40 (20л)
2200000013682 Моторное масло ARAL SuperTurboral SAE 5W-30 (20л)
4008177965005 Гидравлическое масло ARAL Vitam DE 32 (20л)
4008177990809 Моторное масло ARAL Turboral SAE 15W-40 (20л)
4008177990175 Моторное масло ARAL MegaTurboral SAE 10W-40 (208л)
2200000013279 Моторное масло ARAL Extra Turboral SAE 10W-40 (60л)
2200000013330 Моторное масло ARAL MultiTurboral SAE 15W-40 (60л)
2200000013248 Моторное масло ARAL BlueTronic SAE 10W-40 (60л)
4008177991271 Моторное масло ARAL Turboral SAE 10W-40 (60л)
2200000013286 Моторное масло ARAL HighTronic SAE 5W-40 (60л)
4003116249246 Моторное масло ARAL MegaTronic SAE 10W-60 (4л)
4003116249277 Моторное масло ARAL MegaTronic SAE 10W-60 (1л)
4008177990182 Моторное масло ARAL Turboral SAE 10W-40 (208л)
4008177943706 Трансмиссионное масло ARAL Getriebeol Hyp Synth. SAE 75W-90 (60л)
4008177959646 Трансмиссионное масло ARAL Getriebeol EP Plus SAE 80W-90 (60л)
4008177964312 Трансмиссионное масло ARAL Getriebeol ATF J (20л)
4008177978890 Трансмиссионное масло ARAL Getriebeol ATF 55 (60л)
4008177990076 Моторное масло ARAL HighTronic SAE 5W-40 (208 л)
4008177990083 Моторное масло ARAL BlueTronic SAE 10W-40 (208л)
4008177990199 Моторное масло ARAL Turboral SAE 15W-40 (208л)
14AF79 BlueTronic 10W-40     20 Liter
154FE6 BlueTronic 10W-40     4 Liter
1529FA BlueTronic 10W-40     5 Liter
14955C BlueTronic 10W-40     60 Liter
14F736 BlueTronic 10W-40    1 Liter
14F738 BlueTronic 10W-40    208 Liter
15318F EcoTronic F 5W-20     1 Liter
15318C EcoTronic F 5W-20     208 Liter
15570E EcoTronic F 5W-20     4 Liter
15318D EcoTronic F 5W-20     60 Liter
1505B4 HighTronic 5W-40 1 Liter
151C11 HighTronic 5W-40 208 Liter
1505B1 HighTronic 5W-40 20 Liter
154FE7 HighTronic 5W-40 4 Liter
1505B2 HighTronic 5W-40 60 Liter
1529F9 HighTronic 5W-40     5 Liter
15B618 HighTronic C 5W-30     1 Liter
154F51 HighTronic C 5W-30     208 Liter
15563C HighTronic C 5W-30  4 Liter
15563B HighTronic C 5W-30     60 Liter
1552A0 HighTronic F  5W-30    1 Liter
15529D HighTronic F 5W-30    208 Liter
1552A2 HighTronic F 5W-30     4 Liter
15529F HighTronic F 5W-30     60 Liter
14FEEE HighTronic G 5W-30     1 Liter
14FEEC HighTronic G 5W-30     208 Liter
155EA7 HighTronic G 5W-30     4 Liter
14FEED HighTronic G 5W-30     60 Liter
14F90C HighTronic J  5W-30       60 Liter
14F90D HighTronic J  5W-30      208 Liter
151CED HighTronic J  5W-30     1 Liter
1555F7 HighTronic J 5W-30     4 Liter
150B6A HighTronic M 5W-40     1 Liter
150B6B HighTronic M 5W-40     208 Liter
154FE8 HighTronic M 5W-40     4 Liter
150B6C HighTronic M 5W-40     60 Liter
14F898 HighTronic R 5W-30       60 Liter
14F899 HighTronic R 5W-30      208 Liter
151CEE HighTronic R 5W-30     1 Liter
1555F2 HighTronic R 5W-30     4 Liter
154FAC MegaTronic 10W-60     1 Liter
15BC4F MegaTurboral 10W-40     208 Liter
15BC45 MegaTurboral 10W-40     20 Liter
15B6C8 MegaTurboral 10W-40     5 Liter
15BC50 MegaTurboral 10W-40 60 Liter
15BD3D MegaTurboral LA 10W-40     208 Liter
15BD3B MegaTurboral LA 10W-40     20 Liter
15AB04 MegaTurboral LA 10W-40     60 Liter
15BD42 MegaTurboral LA 10W-40   4 Liter
15567F MegaTurboral S 10W-40     208 Liter
15555A MegaTurboral S3 10W-40     208 Liter
15555B MegaTurboral S3 10W-40     60 Liter
1557B4 MegaTurboral VR 10W-40     208 Liter
1557B5 MegaTurboral VR 10W-40     20 Liter
1557B6 MegaTurboral VR 10W-40     60 Liter
151CA2 SuperTronic 0W-40 (Low SAPS)     208 Liter
14AF3B SuperTronic 0W-40 (Low SAPS)     20 Liter
14950C SuperTronic 0W-40 (Low SAPS)     60 Liter
14F800 SuperTronic 0W-40 (Low SAPS)    1 Liter
154FED SuperTronic 0W-40 (Low SAPS)    4 Liter
151CA3 SuperTronic E 0W-30     208 Liter
154FEE SuperTronic E 0W-30   4 Liter
149A1B SuperTronic E 0W-30     60 Liter
14F802 SuperTronic E 0W-30    1 Liter
15A8B0 SuperTronic G 0W-40     208 Liter
15A8AF SuperTronic G 0W-40     60 Liter
15A8AD SuperTronic G 0W-40    4 Liter
15A8AE SuperTronic G 0W-40    1 Liter
15135C SuperTronic Longlife III 5W-30     208 Liter
14AF40 SuperTronic LongLife III 5W-30     20 Liter
152A0E SuperTronic Longlife III 5W-30     5 Liter
14954B SuperTronic LongLife III 5W-30     60 Liter
14F7FD SuperTronic LongLife III 5W-30    1 Liter
15503C SuperTronic LongLife III 5W-30   4 Liter
15B6B5 SuperTronic LL IV FE 0W20 1 Liter
15B6B7 SuperTronic LL IV FE 0W20 208 Liter
15B6B6 SuperTronic LL IV FE 0W20 60 Liter
1556AA SuperTurboral  5W-30    208 Liter
1556A9 SuperTurboral  5W-30    20 Liter
1556AD SuperTurboral 5W-30     4 Liter
1556AC SuperTurboral 5W-30     60 Liter
15870F SuperTurboral LA 5W-30     208 Liter
15870E SuperTurboral LA 5W-30     20 Liter
15871F SuperTurboral LA 5W-30     4 Liter
15871A SuperTurboral LA 5W-30     60 Liter
15BCCA Turboral 10W-40      1 Liter
15BCD3 Turboral 10W-40      208 Liter
15BCD2 Turboral 10W-40      20 Liter
15BCD5 Turboral 10W-40      5 Liter
15BCD4 Turboral 10W-40      60 Liter
15BC5E Turboral 15W-40       20 Liter
15BC64 Turboral 15W-40       60 Liter
15BC61 Turboral 15W-40      208 Liter
15554B Turboral 15W-40      5 Liter
15B6C6 Turboral 15W-40     1 Liter
15569F Turboral 20W-20     208 Liter
15569E Turboral 20W-20     20 Liter
15BBD3 Turboral 20W-50     1 Liter
15BBD2    Turboral 20W-50     208 Liter
15BBD1    Turboral 20W-50     20 Liter
15BBD4 Turboral 20W-50     5 Liter
Aral HighTronic 5w40 API SL
Aral High Tronic 5W-40
Aral SuperTronic 0W-40
Aral SuperTronic G 0W-30
Aral SuperSynth 0W-40
Аral Ep Synth 75w-90 API GL-4/5
Aral Getriebeöle EP Synth 75W-90 API GL-4+
Aral Supertronic G 0W-30 отработка на Lada Granta после 4400км.
Аral Supеr Trоnic 0w-40 отработка на Lеxus после 11300км
Ответили с Lotos
Мы не разливаем Арал. Но некоторые бренды у нас на заводе разливаем - но мы не можем разглашать информацию какие бренды у нас разливаются.
Zbignev Juchnevic
Eastern Markets
Foreign Trade Office
Бытует мнение,что Пентос бочковой идет из Калуги от Фукса.Поэтому бочки больше не берем,только фасовка,она 100% из Германии.Но это надо переносить в Пентос.
Оффтоп
Здравствуйте, не Пентозин в калуге не производится. Импорт
С уважением,
Горобец Максим,
Региональный представитель по ЦФО
Направление Транспорт и Тяжелая техника
maksim.gorobets@fuchs-oil.ru
Ну и слава богу,значит фейки.
А от кого приходилось слышать такие речи?
В узком кругу специалистов.Но не будем это развивать.Думаю так,если поляки не говорят что они там разливают(какая тут тайна?),то не стоит доверять их отпискам.
Так Rowe тоже не говорит, кто у неё бодяжится. Просто так принято своих 'контрактников' не светить.
коммерческая.
В принципе, можно сравнить днища канистр. У разных прессформ должны быть свои отметки для внутренней идентификации.
В 21.03.2018 в 12:50, maks0578 сказал:
 А кто у Вас в РБ дилер ARAL ? (тот же , что пентос и srs ).
нет)
оф дилер в РБ теперь уже тот же, кто и CASTROL+BP.  После того как BP купил ARAL и контракты перешли к дилерам  Castrol
17 минут назад, UMMS сказал:
Вот на Бехтерева оф. магазин Castrol - зайду специально посмотрю.
А вот прежний дилер - работает по старому.
http://oilprofi.by/ru/catalog/motornye-masla.html?custom_parent_id=1&suppliers_oil=ARAL
Интересующиеся могут обратить внимание на бросовые цены на:
Масло приятное, по мне из-за снижения цен конкурент фуксу намечается. Особенно в ЛЛ3 масле.
login1 STPK в автодоке?
8 часов назад, login1 сказал:
Skif_tlt Ага. Он самый)
Чот не заметил конкуренции фуксу по цене))
