Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
Я не изучал вопрос по моторным маслам и другим техническим жидкостям Febi , но копал по их смазкам - мой вывод - смазки свои они покупают в Германии у проверенных специализированных производителей смазок . Отдельные смазки ( например для ШРУС ) они вообще покупают ровно те же , что идут в качестве оригинальных сервис-смазок Mercedes-Benz , Opel , VW/Audi . Со смазками для обслуживания тормозов "кухня" такая же . Это при том , что детали подвески они закупают самые низкокачественные , какие только можно найти .
Ваши объяснения совершенно не нужны, потому что в этом сертификате, выданном Ferdinand Bilstein GmbH + CO.KG в 1994 г., чёрным по белому указана область его действия, а именно (цитирую дословно) - "Разработка, изготовление и продажа запчастей и прецизионных, обработанных на токарном станке деталей для автомобилей."
Так что моторные масла, если они и разливаются по канистрам под эгидой Febi ни коим образом не касаются выложенного вами скана сертификата TUV.
Кстати, если вы действительно являетесь почитателем моторных масел Febi, то почему не выложите в тему сканы этикеток и маркировок канистр или скан российского сертификата соответствия на эти масла?
Вам лень поискать данные - это Ваши проблемы. Не понимаете зачем суппорт у производителя - видимо не желаете изучать матчасть. Не понимаете, откуда масла - так не покупайте. Тем более, Вы ими НЕ интересуетесь. Для одарённых - масла Феби есть в Техдоке, который ТЮВ сертифицирован. Вы считаете и там тоже врут ? Это Ваше право. Как есть Маннол в Техдоке, который льёт Вольеф,  но которого нет на Бево. За сим откланиваюсь.
Для справки - моторное масло юридически называется ДЕТАЛЬ (ЗАПЧАСТЬ). Были напряжённые споры с налоговой по поводу торговля запчастями и маслами. Якобы на масла нужен отдельный вид деятельности открывать. Решение суда указало, что масло ДЕТАЛЬ. Аллес.
Изменено пользователем apex75
Вам лень поискать данные - это Ваши проблемы...
Поскольку от вас так и не поступило ни одной конкретной информации относительно производства моторного масла Febi, пришлось самому взглянуть, например, в этот ресурс, содержащий сведения почти о сотне маслоделов в т.ч 20-ти из Германии, в нём ни какого упоминания о Febi нет.
Поскольку моторные масла под маркой Febi всё таки предлагаются на российском рынке, остаюсь при прежнем мнении, что Febi сам не производит моторные масла, а в лучшем случае их фасует где то, а то и просто целиком заказывает на стороне.
Бинго ! На ШЕСТОМ моём упоминании о SRS Вы поняли, что Фэби заказчик, а не производитель масел. И разумеется ВЫ ни одной моей ссылки не открыли, ну правильно, зачем же.
Ну почему же не открывал? Не так уж и сложно было жмакнуть разок на единственную вашу ссылку и, оказавшись прямиком на торговом ресурсе, рассмотреть у масла Febi- nr.32932 допуска MB и VW. а потом по бюллетеням этих автопроизводителей убедиться в отсутствии у этого масла этих допусков.
Уважаемый, Вы не правы.
Mannol уже лет 100 не льется на Wolf!!!!
Канистра Febi, SRS и еще многих и многих других брендов , слишком популярна и скорей всего очень дешевая вот и льют в них что смешают.
До сих пор не могу понять почему у них такие дешёвые антифризы и спец жидкости... очень подозрительно!
Я б не сказал, что дешёвые антифризы. Концентраты наравне с Hepu по цене..
В поисках нужных амортизаторов набрел на сайт Febi - ну и масло посмотрел заодно.Вбил каталожные номера в поиск и оказалось, что сейчас эти масла у АВТОДОКа очень даже недороги. Даже Лукойл Генезис дороже. Понятно, что Febi упаковщик, но так же понятно, что масла Европейские и уж точно не подделка.
Например: Febi (32932) 10W-40 4L - 969 рублей.
                   Febi (32937)  5w-40   4L - 1134 рубля.
                   Febi (32942)  5W-30  4L -1307 рублей.
CLP32936_RUS.PDF
Кто в этом понимает, может пояснить состав??
ТУТ прочитал что я якобы Феби производит оригинальные масла MB. Чуть со стула не упал..что за бред!
Феби всегда был низкокачественным дешевым аналогом!
Моторные масла никакущие! Тормозная жидкость, жидкость в ГУР - все очень слабенькое!
Про запчасти без мата вообще никак.....
так и есть что феби в свое время заняли нишу типа ориджинал вот теперь народ и ведется на это. а такие канистры очень популярны среди немцев, у дивинола точь в точь, только те красные. каждый немецкий производитель заявляет что льется с конвеера. в германии столько машин нет. скоро японцы начнут ваговские номера на банках клепать и будут как оригинальная маслозапчасть)))
Изменено пользователем Joy
Да, сейчас именно оно в канистрах МВ....
а мне говорят что Fuchs
Блин, да Fuchs, вроде как был..., просто ребята в сервисе заменяют Febi, хотя и без оф. допусков - проблем не было, правда в основном в АКПП льют. Просто почему вспомнилось, вроде как краем уха слышал, что теперь оригинал идёт Febi...
В сервисе у людей задача не в масле разбираться, а гайки крутить. Фукс делает масла мб и сейчас. Бочки мерседес масел вообще в Калуге произведены. В том числе и АТФ 236.14 Изменено пользователем Antonmsk
