Масло Febi
32941 - Febi Engine Oil Longlife 5W-30 1L
32947 - Febi Engine Oil Longlife Plus 5W-30 5L
32921 - Febi 20W-50 1L
32922 - Febi 20W-50 5L
32923 - Febi 20W-50 25L
32924 - Febi 20W-50 60L
38408 - Febi 20W-50 200L
32925 - Febi 15W-40 1L
32926 - Febi 15W-40 4L
32927 - Febi 15W-40 5L
32928 - Febi 15W-40 25L
32929 - Febi 15W-40 60L
32930 - Febi 15W-40 200L
32931 - Febi     10W-40    1
32932 - Febi     10W-40    4
32933 - Febi     10W-40    5
32934 - Febi     10W-40    60
32935 - Febi     10W-40    200
32936 - Febi     5W-40    1
32937 - Febi     5W-40    4
32938 - Febi     5W-40    5
32939 - Febi     5W-40    60
32940 - Febi     5W-40    200
32941 - Febi     5W-30 Longlife    1
32942 - Febi     5W-30 Longlife    4
32943 - Febi     5W-30 Longlife    5
32944 - Febi     5W-30 Longlife    60
39336 - Febi     5W-30 Longlife    200
32945 - Febi     5W-30 Longlife Plus    1
32946 - Febi     5W-30 Longlife Plus    4
32947 - Febi     5W-30 Longlife Plus    5
32948 - Febi     5W-30 Longlife Plus    60
39337 - Febi     5W-30 Longlife Plus    200
34052 - Febi     10W-40 Truck Longlife Plus    200
48416 - Febi     5W-30 Longlife EU6    205
101140 - Febi     0W-40    1
101141 - Febi     0W-40    4
101142 - Febi     0W-40    5
101143 - Febi     0W-40    60
101144 - Febi     0W-40    200
105840 - Febi     10W-40 Truck Special Longlife    5
34047 - Febi     10W-40 Truck Special Longlife    20
34048 - Febi     10W-40 Truck Special Longlife    60
34049 - Febi     10W-40 Truck Special Longlife    200
101150 - Febi     5W-30 HC-FO    1
101151 - Febi     5W-30 HC-FO    4
101152 - Febi     5W-30 HC-FO    5
101153 - Febi     5W-30 HC-FO    60
101154 - Febi     5W-30 HC-FO    200
108350 - Febi     5W-20 HC E-FO    1
108351 - Febi     5W-20 HC E-FO    4
108352 - Febi     5W-20 HC E-FO    5
108360 - Febi     5W-30 HC C4    1
108361 - Febi     5W-30 HC C4    4
108362 - Febi     5W-30 HC C4    5
Febi SAE 5W-30 Longlife
Febi SAE 10W-40 Truck Special Longlife
Febi SAE 0W-40
Febi SAE 5W-40
Febi Longlife Plus 5W-30
Febi Long Life HC-FO 5W-30
Febi Zentralhydraulikol
Лабораторные анализы - Отработки - UOA
Febi Loglife Plus 5W-30 отработка на Volkswagen Touareg после 8700км
Febi Long Life HC-FO 5W-30 отработка на TOYOTA VERSO  после 8000 км
Febi SAE 0W-40 отработка на Skoda Yeti после 6760км
да про феби явный пи..ешь про то что они для мерсов. кто то про митасу лечит что ориганал для свех япов льет.
у меня корешу в Киеве в сиат такой лили и говорили что это есть его оригинал и меняй мол 15тык не раньше. но я не скажу что он его там дешево брал. на базаре два дурака.
Изменено пользователем Joy
По "неофициальной информации от первоисточника" в настоящее время FEBI закупает моторные масла у немецкого производителя ROWE. Сам ROWE имеет все необходимые допуски (в частности VW) , поэтому FEBI не считает целесообразным проходить дополнительную сертификацию под своим брендом.И по этой же причине масло FEBI имеет достаточно привлекательную цену.
Ну если ROWE производитель, это внушает. А допуски как и все этикеточники не получают - обычная практика, точно так же у NGN, да и у многих в общем то.
@transporter73, спроси о официальных представителей все артикулы их масел, что бы к шапке темы прилепить и народ мог покупать на емексах экзистах и цены смотреть на их масла. :) Если можешь конечно :)
От того что они закупают у ROWE, не означает что рецептура не меняется.
Как правило производителя загоняют в определенный бюджет...
Достаточно просто заглянуть в MSDS, чтобы убедиться в этом
Масло моторное SAE 5W-30 Longlife Plus (5,0 L) синтетическое VAG - 504.00/507.00 /MB - 229.51/ BMW - Longlife 04 /OPEL/DACIA/RENAULT/DAEWOO/KIA
Номер по Феби 32947
Масло моторное SAE 5W-30 Longlife (1,0 L) синтетическое
AUDI/VW/SKODA/SEAT/MERCEDES/BMW/OPEL/DAC IA/RENAULT/DAEWOO/KIA
Номер по Феби 32941
Мне кажется ,для этого не стоит беспокоить представителей :).Всё есть на их сайте , вполне удобный подбор с артикулами :                                           http://www.febi-parts.com/article.php
Чё то ссылка с пустым поиском получилась )). Там в поисковой строке надо написать "моторное масло" и выдаёт 43 результата с артикулами ,есть фильтры по язкости ,объёму и т.д.
Я по немецки не понимаю, ввел моторное масло ничего не вышло. Списком бы в виде
123456 - Febi 5W-40 1L
123456 - Febi 5W-40 4L
Я бы все в шапку добавил. Народу это полезно, Febi это очень полезно, люди будут находить их продукты и покупать. Rowe хороший немецкий производитель, будут искать здесь.
hhKEGatq0EqI.pdf
А в виде pdf пойдёт ?) Вручную же долго писать ))
Изменено пользователем transporter73
p.s. Не подумайте , что я распостранитель масел FEBI ). Никакого отношения к ним не имею. Сам пока что езжу на Wolf , но его изначально привлекательная цена растёт с каждым днём , вот и задумался о более бюджетном масле ,желательно без потери в качестве :)
@transporter73, ладно спасибо чем смог... Там названия масла нет просто в pdf написано моторное масло. Так я не выложу артикулы. :)
Производитель Febi Артикул 32931 Вес 871 г г Вязкость 10W-40 Объем 1 л л Состав Полусинтетическое Спецификации ACEA B3, B4, A3 Спецификации API SL Спецификации OEM MB 228.3, MB 229.1, VW 502.00, VW 505.01 Габариты 222x112x65 мм мм
Производитель
  Febi Артикул 32936 Вес 921 г г Вязкость 5W-40 Объем 1 л л Состав Синтетическое Спецификации API CF, SM Спецификации OEM BMW Longlife-98, Porsche, VW 502.00, VW 505.00
Производитель
Производитель Febi Артикул 32941 Вес 900 г г Вязкость 5W-30 Объем 1 л л Спецификации API CF, SM Спецификации OEM BMW Longlife-04, MB 229.51, VW 502.00, VW 505.00
Производитель
  Febi Артикул 32945 Вес 852 г г Вязкость 5W-30 Объем 1 л л Спецификации ACEA B4, A3 Спецификации OEM BMW Longlife-04, MB 229.51, VW 504.00, VW 507.00
Производитель Febi Артикул 32932 Вес 3780 г г Вязкость 10W-40 Объем 4 л л Состав Полусинтетическое Спецификации ACEA B3, B4, A3 Спецификации API CF, SL Спецификации OEM MB 229.1, VW 501.01, VW 505.00
Производитель
  Febi Артикул 32933 Вес 4707 г г Вязкость 10W-40 Объем 5 л л Состав Полусинтетическое Спецификации ACEA B3, B4, A3 Спецификации API CF, SL Спецификации OEM MB 229.1, VW 501.01, VW 505.00
Производитель
  Febi Артикул 32937 Вес 3740 г г Вязкость 5W-40 Объем 4 л л Состав Синтетическое Спецификации API CF, SL Спецификации OEM BMW Longlife-98, GM-LL-B-025, MB 229.3, Porsche, VW 502.00, VW 505.00
Производитель Febi Артикул 32942 Вес 3750 г г Вязкость 5W-30 Объем 4 л л Спецификации API CF, SM Спецификации OEM BMW Longlife-04, MB 229.51, VW 502.00, VW 505.00
Производитель Febi Артикул 32938 Вес 4714 г г Вязкость 5W-40 Объем 5 л л Состав Синтетическое Спецификации ACEA B3, B4, A3 Спецификации API CF, SL, SM Спецификации OEM BMW Longlife-98, GM-LL-B-025, MB 229.3, Porsche, VW 502.00, VW 505.00 Тип контейнера Канистра пластик
Производитель Febi Артикул 32943 Вес 4630 г г Вязкость 5W-30 Объем 5 л л Спецификации API CF, SM Спецификации OEM BMW Longlife-04, MB 229.51, VW 502.00, VW 505.00
Производитель
  Febi Артикул 32947 Вес 4620 г г Вязкость 5W-30 Объем 5 л л Спецификации ACEA B4, A3 Спецификации OEM BMW Longlife-04, MB 229.51, VW 504.00, VW 507.00
Производитель Febi Артикул 32934 Вес 52260 г г Вязкость 10W-40 Объем 60 л л Состав Минеральное Спецификации ACEA B3, B4, A3 Спецификации API CF, SL Спецификации OEM MB 229.1, VW 501.01, VW 505.00
роизводитель
  Febi Артикул 32948 Вес 51120 г г Вязкость 5W-30 Объем 60 л л Спецификации ACEA B4, A3 Спецификации OEM BMW Longlife-04, MB 229.51, VW 504.00, VW 507.00
Производитель
  Febi Артикул 32935 Вес 174 г г Вязкость 10W-40 Объем 200 л л Состав Полусинтетическое Спецификации ACEA B3, B4, A3 Спецификации API CF, SL Спецификации OEM MB 229.1, VW 501.01, VW 505.00
Febi, Swag, blue print и bilstein это все варится в одном котле так же советую вам осмотреть канистру оригинального масла мерседес вероятнее всего вы увидите ту же канистру что и у febi.
febi и swag делают только резину(втулки, сайлентблоки, подушки и.т.п.) остальное они покупают клеймят раскладывают в свои коробки и продают.
